tvendett
#1 Posted : 15 years ago
tvendett
Hello,
I am not getting any water out of my dispenser. The following is what I have attempted to do already. Your help will be greatly appreciated.
I have purchased from you and installed the following parts:
1). WR62X10055 - SOLENOID ASM
2). WR57X10032 - WATER VALVE
3). WR49X10233 - SPRING TORSION FIT
4). WR17X11267 - FUNNEL ICE DISPLAY
5). WR17X11170 - HOUSING SHIELD DISP
6). WR17X10706 - CRANK DOOR RECESS
7). WR23X10224 - SWITCH
8). WR02X10585 - SPRING RECESS DOOR
Additionally I have validated the water source to the unit is good. I have replaced the water filter and reset it. I held the water dispenser down several times for more than 3 minutes with no results. (HELP)
tvendett
#2 Posted : 15 years ago
tvendett
Does anyone out there have any suggestions?
applianceman
#3 Posted : 15 years ago
applianceman
At the bottom if the door there is a connector take that connector apart, close the door and try to dispense water and if you get water to come out the hose then the line is frozen in the door.
If this is the case open the door and press the door switch and repeatedly press the switch to dispense water until water comes out the door.
GE makes a heater that will stop this from happening again.
Also if that is not the problem see if the lights dim when you try to dispense water and if so the main board is the prolblem.
Try this page GE Refrigerators Repair Guide
tvendett
#4 Posted : 15 years ago
tvendett
Applianceman,
Thank You for the addvice, it was exactly what you indicated.
TimV
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 about a year ago
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 2 years ago
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 2 years ago
Kenmore Elite 795.72489.411 water dispenser not working (Refrigerator & Freezer Repair)
by fjfagergren 4 years ago
Water dispenser not working hums but no water. (Refrigerator & Freezer Repair)
by mouse51180 6 years ago
Water Dispenser not working but ice maker is still working (Refrigerator & Freezer Repair)
by Bobby-Houston 6 years ago
by tmeiss 9 years ago
Water dispenser not working, parts replaced (Refrigerator & Freezer Repair)
by pdog 10 years ago
GE Refrigerator water dispenser not working (Refrigerator & Freezer Repair)
by Jinxpalm 10 years ago
Water dispenser not working with filter. Works without filter (Refrigerator & Freezer Repair)
by kathut 11 years ago
by help810 11 years ago
LG Frig Ice & Water dispenser not working, No Light (Refrigerator & Freezer Repair)
by LG_Frig_Dispenser_Problem 11 years ago
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11 years ago
produce drawer too cold; water dispenser not working (Refrigerator & Freezer Repair)
by houseofreg 12 years ago
water dispenser not working after actuator replacement (Refrigerator & Freezer Repair)
by rd27 12 years ago
