plywood50
#1 Posted : 15 years ago
plywood50
My ice dispenser will not dispense the ice the auger motor is good tested it and it turns. Could it be the micro swith in the panel or the panel itself?
#2 Posted : 15 years ago
It can be a bad micro switch as well as a bad control board or wire harness. You have to take it apart and diagnose. Be advised that the power board for the is model is no longer available.
Here are the breakdown diagrams and Dispenser replacement parts for FRIGIDAIRE FRS23R4AW2 Frigidaire\refrigerator | AppliancePartsPros.com
plywood50
#3 Posted : 15 years ago
plywood50
If it is the panel what next?
#4 Posted : 15 years ago
Then it has to be replaced.
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave about a year ago
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern about a year ago
Door Ice dispenser not functioning properly (Refrigerator & Freezer Repair)
by abennet4@comcast.net about a year ago
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 2 years ago
Ice dispenser light on Frigidaire FGHC2342LF3 not working (Refrigerator & Freezer Repair)
by parkerfly 2 years ago
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 2 years ago
how to determine if kenmore ice dispenser is bad (Oven Repair (including Ranges and Cooktops))
Frigidaire water/ice dispenser issue FFHS2322MSKA (Refrigerator & Freezer Repair)
Ice dispenser freezing (Refrigerator & Freezer Repair)
by jesus freak 2 years ago
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 2 years ago
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 2 years ago
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 3 years ago
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 3 years ago
Frigidaire FRS6LF8FS1 ice dispenser not dispensing ice (Refrigerator & Freezer Repair)
by BradASchreiber 3 years ago
Water/ice dispenser funnel won’t retract (Refrigerator & Freezer Repair)
