plywood50
#1 Posted : Thursday, July 1, 2010 11:47:58 AM(UTC)
plywood50
My ice dispenser will not dispense the ice the auger motor is good tested it and it turns. Could it be the micro swith in the panel or the panel itself?
#2 Posted : Thursday, July 1, 2010 7:20:01 PM(UTC)
It can be a bad micro switch as well as a bad control board or wire harness. You have to take it apart and diagnose. Be advised that the power board for the is model is no longer available.
Here are the breakdown diagrams and Dispenser replacement parts for FRIGIDAIRE FRS23R4AW2 Frigidaire\refrigerator | AppliancePartsPros.com
plywood50
#3 Posted : Friday, July 2, 2010 10:40:37 AM(UTC)
plywood50
If it is the panel what next?
#4 Posted : Friday, July 2, 2010 2:15:30 PM(UTC)
Then it has to be replaced.
Guest (4)
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Door Ice dispenser not functioning properly (Refrigerator & Freezer Repair)
by abennet4@comcast.net 12/6/2023 4:45:55 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Ice dispenser light on Frigidaire FGHC2342LF3 not working (Refrigerator & Freezer Repair)
by parkerfly 9/2/2023 10:27:54 AM(UTC)
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 7/11/2023 11:36:45 AM(UTC)
how to determine if kenmore ice dispenser is bad (Oven Repair (including Ranges and Cooktops))
by Guest 7/6/2023 3:32:28 PM(UTC)
Frigidaire water/ice dispenser issue FFHS2322MSKA (Refrigerator & Freezer Repair)
by Guest 6/4/2023 10:21:19 PM(UTC)
Ice dispenser freezing (Refrigerator & Freezer Repair)
by jesus freak 1/22/2023 11:25:08 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 12/18/2022 11:23:17 AM(UTC)
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 7/25/2022 3:46:45 PM(UTC)
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 6/16/2022 10:57:08 AM(UTC)
Frigidaire FRS6LF8FS1 ice dispenser not dispensing ice (Refrigerator & Freezer Repair)
by BradASchreiber 5/31/2022 10:45:28 AM(UTC)
Water/ice dispenser funnel won’t retract (Refrigerator & Freezer Repair)
by Guest 2/5/2022 1:15:16 PM(UTC)
