patg
#1 Posted : Friday, May 30, 2008 11:10:43 AM(UTC)
patg
i have this stove-when i try to set the temperate for the oven or convention oven over 285- the err shows up and the oven will not heat. if i set the oven for under that temperate it works properly. what is the problem? thanks
abadfish66
#2 Posted : Friday, May 30, 2008 11:12:47 AM(UTC)
abadfish66
I bet you have the degrees in celsius instead of farenhiet...Do you have the owners manual, if not I will help you get it back to farenhiet
patg
#3 Posted : Friday, May 30, 2008 11:29:08 AM(UTC)
patg
that would be great. the stove is in phoenix-we were moving my mom's stuff and at the new house. it won't work. i couldn't find the manual. i will be going back to phoenix in about 10 days. i have no phone there. what should i do?
abadfish66
#4 Posted : Friday, May 30, 2008 11:42:09 AM(UTC)
abadfish66
I live in Mesa, AZ :) You will need to press bake and broil buttons together until you see SF displayed on the clock.........Next press Broil, this changes the degrees from C to F, Make sure you see F on the display....Press start pad and your good to go....Let me know if that did it...
patg
#5 Posted : Friday, May 30, 2008 12:06:59 PM(UTC)
patg
hey thanks a ton. i hope this works. i won't be able to try to fix this problem for a couple of weeks. i go back and forth, but must stay here for a couple more weeks. thanks again.
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
