eelman
#1 Posted : Wednesday, May 28, 2008 10:09:20 AM(UTC)
eelman
Gas Oven Just Stopped Working. Top Burners Ok, Broiler Ok, Oven Igniter Glows Bright And Hot, No Gas Is Coming Out To Be Lit. Can The Gas Control Valve Work For The Broiler And Fail For The Oven, Or Is The Problem Elsewhere?
abadfish66
#2 Posted : Wednesday, May 28, 2008 7:22:15 PM(UTC)
abadfish66
Very well could be the glow bar, even though it glows red, it may not be drawing enough amps to open the gas valve
eelman
#3 Posted : Thursday, May 29, 2008 4:55:50 AM(UTC)
eelman
yes, possible, but not definitive. could be the valve (?). I dont want to replace parts until it works, I would like to determine which part is the problem... The gas valve is not located next to the igniter bar, so how does the igniter open the gas valve?
abadfish66
#4 Posted : Thursday, May 29, 2008 7:12:30 AM(UTC)
abadfish66
The gas valve is located behind the bottom drawer. If you are able to take an amp reading fron the glow bar, that will tell you if it is good or not. The glowbar is connected to the gas valve, and when the glowbar turns on and draws about 3.3 to 3.6 amps it opens up the gas valve. Let's say the glowbar is drawing 2.8 amps, the gas valve will never open up.
fenceroy
#5 Posted : Thursday, May 29, 2008 10:33:27 AM(UTC)
fenceroy
built in oven, won't light, pilot is on.
eelman
#6 Posted : Saturday, May 31, 2008 6:10:20 AM(UTC)
eelman
I took the back covers off and have exposed the igniter wires. Looks like the igniter is fed by a wire from the thermostat(?), and exits to the gas valve. So I should disconnect the gas valve wire and place my meter leads between that wire and the valve to read amps? I would have already tried that, but I have to get a new meter, mine only reads DC amps (and radio shack here does not carry that type).
Guest (5)
frigidaire oven wont heat after self clean (Oven Repair (including Ranges and Cooktops))
by chalooch101 10/14/2019 5:04:21 AM(UTC)
Oven wont heat or broil (Oven Repair (including Ranges and Cooktops))
by artpell 12/25/2014 1:04:08 PM(UTC)
GE Profile electric single wall oven wont heat (Oven Repair (including Ranges and Cooktops))
by PRWATTS 8/28/2014 8:31:49 PM(UTC)
Oven wont heat (Oven Repair (including Ranges and Cooktops))
by txtrevor 4/4/2014 8:47:16 AM(UTC)
Oven wont Heat up (Oven Repair (including Ranges and Cooktops))
by belliemom 2/28/2014 5:20:18 PM(UTC)
by cullough22 1/11/2014 6:35:17 AM(UTC)
Kitchenaid Gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Travelguy 1/1/2014 5:52:03 PM(UTC)
Oven wont heat up (Oven Repair (including Ranges and Cooktops))
by shellyrodriguez 11/23/2013 8:55:12 AM(UTC)
sears/kenmore elements/oven wont heat (Oven Repair (including Ranges and Cooktops))
by KERMITT454 7/19/2013 4:51:23 PM(UTC)
Maytag Gemini Oven wont heat (Oven Repair (including Ranges and Cooktops))
by Stevewk 5/15/2013 3:12:12 PM(UTC)
Frigidaire Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by GHog 5/7/2013 3:18:52 PM(UTC)
ge wall oven wont heat up (Oven Repair (including Ranges and Cooktops))
by henson1166 1/5/2013 5:08:07 AM(UTC)
Roper electric oven wont heat (Oven Repair (including Ranges and Cooktops))
by fireguy 12/20/2012 7:43:38 PM(UTC)
oven wont heat burners work (Oven Repair (including Ranges and Cooktops))
by michellem 10/2/2012 3:59:41 AM(UTC)
Xfe361lvb Oven Wont Heat,no Error Codes (Oven Repair (including Ranges and Cooktops))
by awvufan76 9/12/2012 10:10:51 AM(UTC)
