2 Pages<12
aedwards
#11 Posted : Monday, June 7, 2010 5:14:37 AM(UTC)
aedwards
Originally Posted by: eclynn Go to Quoted Post
The infra-red circuit board for mine was located behind the sliding switch on the right side to turn the ice maker off/ on. The other side of the freezer is where the other board is, the receiving side of the infra-red. Both boards are inside the freezer. The boards came as a set when I ordered them.
Good Luck.
Thanks.
AEdwards
dicknuc
#12 Posted : Monday, June 7, 2010 10:25:58 AM(UTC)
dicknuc
Your inlet tube that goes to the icemaker may be frozen.
To Check: Shut off water supply to Fridge, disconnect the
water line that goes to the icemaker at top back.
Use a flexible item to insert in the water line connection.
I used a zip tie. If the flexible item won't all the through
to the ice maker, the line is frozen. Thaw out the tube
from inside the freezer with a hair dryer. Re-connect
everything, you now have ice . . .
Solution #2: You may have to replace your "Water Inlet
Valve" located at bottom right rear of Fridge.
Easy to do, just follow the color codes, be sure and shut
off the water.
aedwards
#13 Posted : Monday, June 7, 2010 11:02:41 AM(UTC)
aedwards
off the water.
I've eliminated the frozen water line by putting water directly into the icemaker. Now I can see the frozen ice cubes but they won't flip out. So based on this and the continuous flashing of the led light even when the icemaker is in the "off" position, I've concluded it's the optics?????
AEdwards
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Ice Maker Problems - Whirlpool (Refrigerator & Freezer Repair)
by tomkarl419 4/27/2022 5:37:11 AM(UTC)
kenmore elite ice maker problem (Refrigerator & Freezer Repair)
by Guest 4/17/2022 3:13:38 PM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Whirlpool In Door Ice maker Problems (Dishwasher Repair)
by mphillips9im 7/17/2021 8:10:42 AM(UTC)
Kenmore side by side ice maker problem (Refrigerator & Freezer Repair)
by DIY987 8/11/2019 3:11:25 PM(UTC)
Kitchen Aid Ice Maker Problem (Refrigerator & Freezer Repair)
by morrepe 8/2/2019 5:56:06 AM(UTC)
GE Ice Maker Problems (Refrigerator & Freezer Repair)
by GM1123 8/16/2015 6:55:23 PM(UTC)
Samsung ice maker problem (Refrigerator & Freezer Repair)
by retiredncolorado 7/31/2015 6:12:07 AM(UTC)
GE fridge ice maker problem (Refrigerator & Freezer Repair)
by zeke1 7/5/2015 7:54:01 AM(UTC)
GE frig ice maker problem (Refrigerator & Freezer Repair)
by CaptJR 7/5/2014 3:59:14 AM(UTC)
kitchen aid side by side ice maker problem (Refrigerator & Freezer Repair)
by richard easter 6/23/2014 2:36:07 PM(UTC)
Whirlpool Gold Ice Maker Problem - Stumped! (Refrigerator & Freezer Repair)
by ljsmith1 11/25/2013 6:06:51 PM(UTC)
GE Arctica Side-by-Side Ice Maker Problems (Refrigerator & Freezer Repair)
by coondog 7/22/2013 2:56:20 PM(UTC)
by K7527 6/11/2013 8:51:25 AM(UTC)
2 Pages<12
