folson
#1 Posted : Sunday, June 6, 2010 6:06:38 PM(UTC)
folson
Just trying to check myself. The non resetable fuses test good. No heat electric dryer. Could it be the element or the termostat?
#2 Posted : Monday, June 7, 2010 2:00:17 AM(UTC)
Replacement parts for WHIRLPOOL LE5720XSW0 | AppliancePartsPros.com
I am assuming that you checked the thermal fuse (Item 7 in Section 3) with a meter and that you disconnected one side of it when measuring. This prevents reading an alternate/parallel circuit path.
[COLOR="Blue"]Just trying to check myself. The non resetable fuses test good. No heat electric dryer. Could it be the element or the termostat?[/COLOR]
Yes it could be either of the above, with the element being the more likely.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord.
[COLOR="Red"]Be careful 240 volts is lethal.[/COLOR]
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Be sure to disconnect one side of and device you are measuring this prevents reading an alternate/parallel circuit path. Also use your most sensitive ohms scale.
There is a good Sticky at the beginning of this forum on meter usage.
folson
#3 Posted : Monday, June 7, 2010 5:10:07 AM(UTC)
folson
Thankyou sir. I went ahead and ordered a new element and thermostat for the cost I also figure it has to be one or the other.:)
folson
#4 Posted : Wednesday, June 9, 2010 5:39:29 AM(UTC)
folson
Originally Posted by: denman Go to Quoted Post
If OK
If OK
If OK
Sir; Thankyou The element was bad received the part yesterday. Installed within a hour so far so good. Thanks
folson
#5 Posted : Wednesday, June 9, 2010 5:41:52 AM(UTC)
folson
:) Thanks The element was bad. Installed yesterday so far so good.:rolleyes::rolleyes:
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
