Eleazar
#1 Posted : Friday, June 4, 2010 6:32:16 PM(UTC)
Eleazar
compressor sound like it work and so is the evaporator fan and the condenser fan but not cooling or freezing at all, I am thinking that is in defrost all the time, but the compressor is runing, does the compressor runs when on defrost? any sugestions?
gabe_1981
#2 Posted : Friday, June 4, 2010 8:06:14 PM(UTC)
gabe_1981
When your compresor is runing, its a good indicatioin that its not in the the defrost cycle ... More than likely you have a bad compresor and or a leak somewhere in the sealed system ... in both cases the whole refriderator should be replaced... your cost to fix sealed system will excede the value of the refridgerator
Eleazar
#3 Posted : Saturday, June 5, 2010 4:52:28 PM(UTC)
Eleazar
that's what I tought, thank you for your help.
Eleazar
#4 Posted : Monday, June 7, 2010 4:19:09 PM(UTC)
Eleazar
is it posible that the start capacitor divice not giving enough volts to the compressor? will the compressor partialy work with -10% volts?
Refrigerator & freezer repair (Refrigerator & Freezer Repair)
by weaw@atlanticbb.net 3/25/2012 3:51:10 PM(UTC)
Refrigerator & Freezer Repair (Refrigerator & Freezer Repair)
by macnchez 5/14/2011 9:46:44 AM(UTC)
by oldtomc 1/30/2010 9:13:22 AM(UTC)
