2 Pages12>
carol5430121
#1 Posted : Friday, May 28, 2010 7:53:32 AM(UTC)
carol5430121
Ice maker not working. Replaced filter, still not working. Arm is in correct posiotion. Don't hear water runing to ice maker.
#2 Posted : Friday, May 28, 2010 1:46:54 PM(UTC)
Locate the water inlet valve with the two solenoids on the back of the refrigerator. Swap the wires between the solenoids. Push the water release lever for the water dispenser and check if the ice maker got water.
If it did, replace the ice maker.
If it did not, replace the water valve and make sure the water feeding tube into the ice maker is not clogged or frozen.
- The water inlet valve Part number: AP2115312
zr800
#3 Posted : Thursday, June 3, 2010 7:40:05 AM(UTC)
zr800
Gene, I have a Frigidaire FRS26HF6BW1 with a similar problem. Although when I removed the hose from the back of the fridge where it goes into the ice maker, it happened to turn on and water came shooting out. So I know water is getting to that point, but not running down the chute into the maker. I thought I would check first whats inside the piece that the line connects to (goes between the outside of fridge and inside / chute) before I went sticking things in there to check for a clog. I did have ice built up in the chute when I started investigating this problem. Any suggestions?
#4 Posted : Thursday, June 3, 2010 8:49:04 PM(UTC)
If the water feeding tube into the ice maker was frozen, that means the water inlet valve does not close all the way. The solution is to replace the water inlet valve.
- The water inlet valve Part number: AP4298908
zr800
#5 Posted : Friday, June 4, 2010 3:14:53 AM(UTC)
zr800
much appreciated, thank you.
zr800
#6 Posted : Friday, June 4, 2010 3:21:44 AM(UTC)
zr800
Any tips on this replacent?
#7 Posted : Friday, June 4, 2010 5:32:03 PM(UTC)
You are welcome. There is nothing very special. Do not forget to turn off the water to the refrigerator and remove the power.
dicknuc
#8 Posted : Saturday, June 5, 2010 8:13:29 AM(UTC)
dicknuc
You're alredy replaced the Water Valver - Still Not Working.
Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable items goes all the way through. Hook back the water line to the icemaker. You will have ice soon.
Read more: http://forum.appliancepartspros...post227249#ixzz0pzmjhvPC
http://forum.appliancepartspros.com
zr800
#9 Posted : Tuesday, June 8, 2010 7:24:38 AM(UTC)
zr800
Shouldn't the first step be to try the hair dryer, and second be replace the water valve?
I assume the water valve is located towards the bottom on the back of the fridge? I haven't even looked yet.
dicknuc
#10 Posted : Tuesday, June 8, 2010 11:49:48 AM(UTC)
dicknuc
Yes, check for the possibility of a frozen ice tube first, if frozen, thaw out the tube with a hair dryer. If the icemaker still doesn't work, you may need a "Walter Inlet Valve" located at the bottom right-back of your Fridge. Easy to Do, just follow the color codes.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
2 Pages12>
