kitchenwitch
#1 Posted : Sunday, May 30, 2010 4:25:35 AM(UTC)
kitchenwitch
The touch control panel on the front of the dishwasher will not function. Service tech says it's bad. Appears to be common complaint. Was there ever a recall or will Maytag replace?
#2 Posted : Monday, May 31, 2010 2:42:10 AM(UTC)
Replacement parts for MAYTAG MDBH955AWW Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10179503.pdf
There is not a recall that I know of.
Cannot comment on whether the control panel is shot as you did niot say what the tech did to troubleshoot this.
Also you did not give any specifics as to what does not work.
Other possibilities would be a bad power connection or a bad door switch or a bad control board.
The usual way to troubleshoot this is to check the control pad with a meter (see the tech sheet). If it checks out OK replace the control board.
Still a bit of a crap shoot but your odds are better.
Maytag Quiet Series 300 Dishwasher Backwall middle clips (Dishwasher Repair)
by Mikewis777 2/24/2016 5:06:57 PM(UTC)
Maytag Quiet Series 300 Clean Light (Dishwasher Repair)
by deryckj 2/16/2012 7:10:59 AM(UTC)
Motor Seal Kit - replace ? - Maytag quiet series 300 (Dishwasher Repair)
by pgiambat 12/6/2011 7:59:26 AM(UTC)
Maytag Quiet Series 300 is locked (Dishwasher Repair)
by dishpan hands 6/21/2010 6:07:38 AM(UTC)
Wheel needed for Maytag Quiet Series 300 (Dishwasher Repair)
by Rhodes19 12/22/2009 6:37:03 AM(UTC)
Maytag quiet series 300 touch start (Dishwasher Repair)
by njgrisan 11/6/2009 4:52:33 AM(UTC)
MAYTAG Quiet Series 300 won't come (Dishwasher Repair)
by Bill_Williams@ca.rr.com 7/1/2009 2:20:19 PM(UTC)
Maytag Quiet Series 300 Won't Start! (Dishwasher Repair)
by brandy2dog 6/28/2009 6:19:43 PM(UTC)
maytag quiet series 300 will not start (Dishwasher Repair)
by lhntx 4/19/2009 4:26:17 PM(UTC)
Maytag Quiet series 300 suddenly is not quiet (Dishwasher Repair)
by 524cent 12/17/2008 9:39:22 PM(UTC)
by elgueraf 6/25/2008 8:37:01 PM(UTC)
