dishpan hands
#1 Posted : Monday, June 21, 2010 6:07:38 AM(UTC)
dishpan hands
My Maytag Quiet Series 300 lock light/button will not operate. No other button/light on the door panel will operate, no cycle will run. :( The lock button will not unlock. Is this a problem with the control panel on the outside of the door... or one of the circuit panels inside the door? Could it be a fuse or something relatively simple to repair? Any suggestions? Thanks so much!:)
notwashingdishes
#2 Posted : Sunday, January 8, 2012 3:45:24 AM(UTC)
notwashingdishes
I just started having the same issue. Did you ever get it fixed?:(
kayakcrzy
#3 Posted : Sunday, January 8, 2012 4:36:53 AM(UTC)
kayakcrzy
There are a few things to try. Hold in the control lock button that is flashing, and the heated dry button at the same time for 5 seconds, and see if that takes the control lock light off. If your dishwasher does not have a heated dry button, then hold in the No Heat dry button, and the control lock button that is blinking at the same time for 5 seconds and see if that clears the light. If that does not work, then kill the power to the dishwasher for about 5 minutes, and then turn the power back on, and then open and close the dishwasher door, and try to start a wash. If that does not do it, then you need a new touch pad. Tom www.applianceeducator.com/parts.htm
