olddognewtrx
#1 Posted : Monday, May 24, 2010 10:00:43 PM(UTC)
olddognewtrx
My maytag wanna be ( admiral manufactured) washer will not engage the tub . I can hear the motor running wide open ,but no spinning. Any suggestions?
sidfink43
#2 Posted : Friday, May 28, 2010 6:02:39 AM(UTC)
sidfink43
The most common cause of your problem is the thrust bearing, this part kit here.
Part number: AP4009132
It is not a difficult repair, but take your time and try to get someone to help. Instructions should be included with the kit.
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
Maytag washer not spinning fast enough to drain (Washer Repair)
by jdeemer 1/2/2013 12:31:23 PM(UTC)
Maytag washer not spinning/draining (Washer Repair)
by randkburns 3/28/2011 9:13:14 AM(UTC)
maytag washer not spinning (Washer Repair)
by olddognewtrx 12/21/2009 5:49:37 PM(UTC)
Maytag washer not spinning properly (Washer Repair)
by tnglc 11/18/2009 3:41:52 PM(UTC)
Maytag washer not spinning (Washer Repair)
by josjim 4/30/2009 8:14:34 PM(UTC)
