olddognewtrx
#1 Posted : Monday, December 21, 2009 5:49:37 PM(UTC)
olddognewtrx
I have a Maytag wanna be washer that is actually an Admiral in disguise that will not spin or pump out . When the timer gets to the pump out/ spin section, it makes a few clicks and then nothing. I bypassed the lid switch to no avail and there is no noise coming from the motor or otherwise when it gets to this point. Im thinking that the timer is bad.
sidfink43
#2 Posted : Wednesday, December 23, 2009 12:45:15 PM(UTC)
sidfink43
If you are certain the motor is not getting power, and the drive pulley will turn easily then it would seem the timer is the problem. Check all of the wiring first between the timer and the motor and clean the contacts on both the timer and the motor.
Here is a service manual for your machine.
http://www.servicematters.com/m...ibrary/docs/16023083.pdf
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
Maytag washer not spinning fast enough to drain (Washer Repair)
by jdeemer 1/2/2013 12:31:23 PM(UTC)
Maytag washer not spinning/draining (Washer Repair)
by randkburns 3/28/2011 9:13:14 AM(UTC)
maytag washer not spinning (Washer Repair)
by olddognewtrx 5/24/2010 10:00:43 PM(UTC)
Maytag washer not spinning properly (Washer Repair)
by tnglc 11/18/2009 3:41:52 PM(UTC)
Maytag washer not spinning (Washer Repair)
by josjim 4/30/2009 8:14:34 PM(UTC)
