I have an ice maker that won't make ice. I recently moved the refrigerator to a new house. Before the move, the ice maker worked fine. I hooked up the water supply line and water works on the door, but I'm not sure water is going into the ice maker. There is a slide switch on the right and a red light that seems to flash a code. It is off then 2 fast blinks. The serial # is SM2632241 it was made 6/02. Any suggestions? Thanks, rangie
Originally Posted by: rangie ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...There is a slide switch on the right and a red light that seems to flash a code... Open the freezer door. Make sure the slide switch on the right is in ON position. Depress the flapper on the left and watch the LED. Post the results. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GD5PHAXLQ00 | AppliancePartsPros.comGene.
