rpolsdorfer
#1 Posted : Wednesday, May 12, 2010 9:27:34 PM(UTC)
rpolsdorfer
The lower oven door locked with an F9 error code after normal use, not a cleaning cycle. I have found the latch switch and wiggled it so it returned to the unlocked position. It seems to want to stick mechanically in the locked position unless it is wiggled just right. It also has been cooking too fast.
What is the reason for the oven door lock? If it is only for self-cleaning I'd rather just disable it entirely. How can I disable it so the oven will still function? If I must repair or replace it, how do I figure out what went wrong? Might it just need WD-40?
Thanks, Ricker
#2 Posted : Thursday, May 13, 2010 10:03:47 AM(UTC)
The problem can be a bad door lock switches as well as a bad oven control board. You may want to check the switches, the door lock motor and their wires first. If there is nothing wrong, replace the control board.
- The door latch assembly (lower oven) Part number: AP4094734
rpolsdorfer
#3 Posted : Thursday, May 13, 2010 1:28:31 PM(UTC)
rpolsdorfer
I found the latch assembly. Where/how do I find the control board?
#4 Posted : Thursday, May 13, 2010 8:04:30 PM(UTC)
The control board shown as #2 on the diagram.
rpolsdorfer
#5 Posted : Friday, May 14, 2010 1:42:27 PM(UTC)
rpolsdorfer
Thanks. $$$$$!! I jammed the motor sensor in the open position. Cheaper. I don't use the self-clean function anyway.
#6 Posted : Friday, May 14, 2010 4:52:06 PM(UTC)
You are welcome. Good idea to save $$$!
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Oven door lock (Oven Repair (including Ranges and Cooktops))
by von.ahouse@hotmail.com 10/29/2017 8:46:57 AM(UTC)
Oven Door Locks on its own (Oven Repair (including Ranges and Cooktops))
by TheTryckster 5/20/2015 11:02:43 AM(UTC)
ge double oven door locked (Oven Repair (including Ranges and Cooktops))
by jswim788 1/31/2015 11:30:12 AM(UTC)
Oven door locked, no power? (Oven Repair (including Ranges and Cooktops))
by reckless67 10/27/2013 1:50:44 PM(UTC)
Self-cleaning oven door locks and unlocks - repost (Oven Repair (including Ranges and Cooktops))
by dgray7114 9/12/2012 11:47:04 AM(UTC)
Thermador Dual fuel range oven door locked and f3 code. (Oven Repair (including Ranges and Cooktops))
by mikey77 7/28/2012 7:14:51 AM(UTC)
by Catherine E 2/2/2012 6:18:56 PM(UTC)
oven door locked after using auto clean??? (Oven Repair (including Ranges and Cooktops))
by sheldon friedland 12/8/2011 6:53:53 AM(UTC)
Whirlpool accubake oven door locking problem (Oven Repair (including Ranges and Cooktops))
by ZDM 10/16/2011 8:53:11 AM(UTC)
GE Profile Oven Door lock stuck on... (Oven Repair (including Ranges and Cooktops))
by johndw 5/27/2011 6:29:32 PM(UTC)
Replaced ERC, now oven door locks continually (Oven Repair (including Ranges and Cooktops))
by tlynchard 4/14/2011 2:54:12 PM(UTC)
Upper Oven Door Locked, No Display, Self-Cleaning (Oven Repair (including Ranges and Cooktops))
by thomasjrozzi 1/9/2011 11:14:15 AM(UTC)
