slim6090
#1 Posted : Tuesday, May 13, 2008 6:03:25 AM(UTC)
slim6090
Removed top and front panel, was able to lift drum to get belt on
the belt is still loose around drum, I did not feel the idler arm when putting
on belt. What am I not doing right?
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 2:09:43 PM(UTC)
SublimeMasterJW
Pages from 31-9076 Advntm 120.pdf (103kb) downloaded 55 time(s). The belt has to be connected to a spring loaded idler simular to one of these. The admiral crosley 2nd from bottom left is it I think. To access it you must remove the rear panel on some models. On some their is no rear panel.
SublimeMasterJW attached the following image(s):
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
SG1000 dryer belt replacement (Dryer Repair)
by Guest 6/28/2021 3:29:53 PM(UTC)
Dryer Belt Whirlpool lew0050pq2 - help (Dryer Repair)
by otj287@gmail.com 3/25/2019 8:43:14 AM(UTC)
GE Dryer Belt keeps breaking (Dryer Repair)
by missle 9/13/2017 7:02:48 AM(UTC)
Dryer Belt Restrainer Melts (Dryer Repair)
by notamechanic 8/15/2015 10:09:07 AM(UTC)
Trying to Replace My Danby Dryer Belt (Dryer Repair)
by PDR51 8/6/2015 8:32:22 AM(UTC)
Dryer belt (Dryer Repair)
by MintJulep 4/27/2015 5:44:33 AM(UTC)
Maytag Dryer belt routing (Dryer Repair)
by Electechab 2/5/2015 2:16:47 PM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Please help me change my dryer belt (Dryer Repair)
by jayathorn 9/10/2014 1:47:01 PM(UTC)
Can't find a replacement dryer belt! (Dryer Repair)
by Pat the Rat 7/22/2014 3:53:40 PM(UTC)
Breaking Dryer belts (Dryer Repair)
by DCG65 7/27/2013 11:56:52 AM(UTC)
Dryer Belt Tensioning/Placement Issue (Dryer Repair)
by formula 1/2/2013 5:07:21 PM(UTC)
dryer belt installation, no pulley (Dryer Repair)
by flamingo 12/12/2012 7:19:25 AM(UTC)
Putting on dryer belt (Dryer Repair)
by Martin Miller 11/2/2012 5:50:02 PM(UTC)
