3 Pages123>
golfman
#1 Posted : Saturday, May 10, 2008 11:43:35 AM(UTC)
golfman
Thanks in advance for all advice.......
This is on "Normal cycle"
The washer will go through the cycles fine but when it get to draining it'll drain without spinning and won't spin in the final spin cycle. It will spin if I catch it in time and open/close the lid. It seems to reset itself. I also can get it to spin if I manually push the knob in and turn it to spin and pull out the knob.
I am thinking the timer but it is $100 and would like a second opinion before I just replace parts.
misterfixall
#2 Posted : Saturday, May 10, 2008 11:52:26 AM(UTC)
misterfixall
if its draining then it seems lid switch is ok. by the way your describing it ,could be timer
golfman
#3 Posted : Saturday, May 10, 2008 12:02:46 PM(UTC)
golfman
Yes, it is draining fine.
#4 Posted : Saturday, May 10, 2008 5:27:25 PM(UTC)
I agree with misterfixall. Most likely the problem is a bad timer.
- The part number for the timer is AP3019781
Here are the break down diagrams for the Whirlpool washer Model LSQ9244EQ0
golfman
#5 Posted : Saturday, May 10, 2008 5:36:33 PM(UTC)
golfman
thanks, I will try the part.
#6 Posted : Saturday, May 10, 2008 5:49:37 PM(UTC)
Keep us posted, please.
golfman
#7 Posted : Wednesday, May 14, 2008 11:59:51 AM(UTC)
golfman
The timer did not work. Same problem
Basically it works fine but I have to be there when I wash. When the soapy water drains and the rinse water drains I need to lift the lid and close it to reset it. Then it will spin otherwise it will not. Any other suggestions? Other than that everything is fine.......
misterfixall
#8 Posted : Wednesday, May 14, 2008 2:00:33 PM(UTC)
misterfixall
you are describing a lid switch problem. but in one of your previous letters you said it was draining, are you sure about that? because as far as i know this model cannot drain or spin if lid switch is defective, we only have your word to go by, so please recheck, thanks
golfman
#9 Posted : Wednesday, May 14, 2008 2:07:36 PM(UTC)
golfman
It drains fine and I still wash clothes in it. I just have to be paying attention to it. As soon as I hear it draining I open it and it is not spinning. When I close it I can hear the tub start spinning. Sometimes I put something in the lid switch and watch it to make sure it's at full speed, which it is.
If it is the lid switch, do I have to take the cabinet off?
Thanks.
#10 Posted : Wednesday, May 14, 2008 2:19:01 PM(UTC)
Due to your washer has a neutral drain transmission, it should stop for a few seconds during the drain to engage the spin. This stop interval operates by timer, that's why the timer has to be replaced.
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
3 Pages123>
