squidman1741
#1 Posted : Sunday, September 2, 2007 11:12:28 AM(UTC)
squidman1741
I put clothes in washer, started normal cycle. Washer filled to proper level, began agitating and quit. Washer will not start, will not run at all. I checked circuit breaker to machine, There is power. What could it be. Does the timer control all the running functions? Please help!!! Thanks.
#2 Posted : Sunday, September 2, 2007 2:10:40 PM(UTC)
Hi squidman1741
If you post the complete model number of your washer (it's located under the lid) I might be able to help you.
squidman1741
#3 Posted : Tuesday, September 4, 2007 8:32:01 PM(UTC)
squidman1741
thanks. i fixed the problem. it was a broken wire.
andyp
#4 Posted : Wednesday, September 5, 2007 4:33:33 AM(UTC)
andyp
My Whirlpool washer recently stopped agitating and the water won't drain. I played with the timer but nothing happens. I unplugged the switch and replugged it. When I pulled the timer knob, the washer started filling with water, but after a few seconds, it stopped and nothing else happened
My whirlpool washer moder number is LSQ9010pw1.
Thanks for any assistance.
#5 Posted : Wednesday, September 5, 2007 8:20:56 PM(UTC)
Hi andyp
The first thing I would check is the lid switch.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
