kfnpemai
#1 Posted : Thursday, May 1, 2008 4:13:14 PM(UTC)
kfnpemai
Where is it located? How do I get to it? and how do I test?
#2 Posted : Friday, May 2, 2008 12:31:38 PM(UTC)
The defrost timer (#24 on the refrigerator parts break down diagram) is located in the control panel in the fresh food compartment.
What was the original problem?
kfnpemai
#3 Posted : Saturday, May 3, 2008 5:35:01 AM(UTC)
kfnpemai
Freezer coils freezing up. Checked heater and it is OK. Is timer located under housing with lights. If so how do I remove housing and check timer?
#4 Posted : Saturday, May 3, 2008 10:15:20 AM(UTC)
Did you perform the troubleshooting as described in one of previous posts: http://forum.appliancepartspros...frigerator-too-warm.html?
Did you check the defrost thermostat?
kfnpemai
#5 Posted : Monday, May 5, 2008 6:32:28 AM(UTC)
kfnpemai
No I didn't. How do you check? For me to get at connections, I have to melt all the ice.
#6 Posted : Monday, May 5, 2008 3:17:52 PM(UTC)
Most common problem in such situation is a bad defrost thermostat. The defrost timer is the last failure suspect. I would replace the defrost thermostat even without testing it, especially because the part is less than $15 and there is a pretty good chance it will solve the problem.
- The part number for the defrost thermostat is AP3475238
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
Belarus Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
