squier3
#1 Posted : Wednesday, April 7, 2010 12:46:47 PM(UTC)
squier3
I have a Whirlpool duet washer and about 25% of the time it doesn't seem to spin at the end of the cycle. I've snaked out all the drains from the pump back the the stand pipe. I also snaked out the house drain. I've check the pump filter, pump, preasure switch and the motor. It spins fine 75% of the time and also in diagnostics mode. my first thought was that they arn't using HE detergent but they are. any ideas?
#2 Posted : Wednesday, April 7, 2010 4:27:19 PM(UTC)
Did it show any error codes?
Perform the diagnostic test as described in the Tech sheet.
squier3
#3 Posted : Wednesday, April 7, 2010 5:56:48 PM(UTC)
squier3
I did perform the diagnostics test. It went thru all cycles just fine and there were no error codes
#4 Posted : Wednesday, April 7, 2010 7:12:06 PM(UTC)
You probably know how hard is to diagnose an intermittent problem. Especially if it does not show up in front of you. I would recommend to wait until this problem will get worse.
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Drains - No Spin (Washer Repair)
by Pallas63 5/20/2022 5:19:47 PM(UTC)
Electolux/Frigidaire fftw4120sw1 agitates, no spin. (Washer Repair)
by wishy_washy 11/19/2021 10:02:42 AM(UTC)
Slow to no spin maytag bravos (Washer Repair)
Belarus Guest 7/28/2021 12:13:49 PM(UTC)
Kenmore Frontload No Spin, but does 2 second fluff spin? (Washer Repair)
by d44boy 3/4/2019 10:18:00 AM(UTC)
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
No spin after first one (Washer Repair)
by Jimbobaloue 3/15/2018 1:40:45 PM(UTC)
Whirlpool Gold Ultimate Care II Agitates but no spin (Washer Repair)
by MikeyVdub 1/8/2018 12:49:57 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Agitates and drains but no spin (Washer Repair)
by Burgerpimp 6/7/2017 10:14:27 AM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
Agitate but no Spin - Brake has lots of grease on it. (Washer Repair)
by movinglikeamovie 8/15/2016 2:27:22 PM(UTC)
Just Humming,No spin,no agitate (Washer Repair)
by buddha131 5/10/2016 3:07:32 PM(UTC)
