d ballew
#1 Posted : Sunday, March 28, 2010 5:30:08 PM(UTC)
d ballew
matag washer motor hums but doesent turn. does that mean its shot? also smells like elec. smoke
magician59
#2 Posted : Sunday, March 28, 2010 8:00:43 PM(UTC)
magician59
Does this happen in all cycles? Disconnect the belt and see if the motor runs without a load on it.
d ballew
#3 Posted : Sunday, March 28, 2010 11:17:59 PM(UTC)
d ballew
not yet but it starts smelling like elec. smoke also and just hums. i checked the ohms on the moter and got a low reading is that bad or what?
#4 Posted : Monday, March 29, 2010 1:00:40 AM(UTC)
If it fails to shut down on it's internal overload, it's missing start current, probably due to a bad timer. You will need a meter to check things.
lat9416aae washer motor substitute (Washer Repair)
by Guest 2/4/2023 12:16:33 PM(UTC)
The pulley on the bottom of my Maytag washer motor has broken. (Washer Repair)
by Guest 9/18/2022 9:05:55 AM(UTC)
maytag bravos washer motor spins but not pulley (Dishwasher Repair)
by brokenwasherman 3/12/2022 7:46:04 AM(UTC)
New GE washer motor won't turn under load (Washer Repair)
by Brunowolf 6/13/2020 2:39:09 PM(UTC)
GE Hydrowave Washer Motor Hot Code (Washer Repair)
by Terry B 4/26/2020 11:13:26 AM(UTC)
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 10/26/2018 8:36:20 AM(UTC)
Washer Motor Part? (Washer Repair)
by Hede003 4/7/2017 9:18:57 PM(UTC)
Washer Motor Sticking (Washer Repair)
by raceaddington 3/11/2017 7:54:41 AM(UTC)
GE Washer Motor Test (Washer Repair)
by bbrennen 8/21/2015 7:41:43 PM(UTC)
GE Washer motor error code not clearing (Washer Repair)
by ragnorok161 7/18/2015 9:24:00 AM(UTC)
KA washer motor overheating (Washer Repair)
by dalack 6/20/2015 7:33:31 AM(UTC)
Finding interchangeable washer motor (Washer Repair)
by toby7 4/4/2015 8:15:20 AM(UTC)
Washer Motor Coupling Keeps Failing (Washer Repair)
by hunter02 2/8/2015 12:52:27 PM(UTC)
Washer Motor Burning Smell (Washer Repair)
by CFB33 10/16/2014 7:57:05 AM(UTC)
GE washer motor interchangeability (Washer Repair)
by circle21 6/3/2014 12:53:44 PM(UTC)
