bbrennen
#1 Posted : Friday, August 21, 2015 7:41:43 PM(UTC)
bbrennen
I just replaced the mode shifter on my washer based on the flash codes displayed. After replacing it I cleared the error codes and verified the LED was flashing in normal mode. When I tried to perform a spin cycle or run in test mode the LED flashes the code the mode shifter is bad. I checked the fuse and that is ok too.
Because the board with the LED is mounted to the motor and as of yet I have no evidence that the motor is working, I was wondering if there is any way to jumper or bypass something to make the motor run so I can at least rule out it's a motor issue.
Thanks,
Bill
fairbank56
#2 Posted : Saturday, August 22, 2015 3:33:03 AM(UTC)
fairbank56
Groups: Expert
Sounds like you have a faulty motor/inverter. There is no way to test the motor. It is a 3 phase DC motor driven by the inverter board.
Eric
bbrennen
#3 Posted : Saturday, August 22, 2015 5:02:50 AM(UTC)
bbrennen
Thanks Eric, that was my other thought. I don't suppose there is a way to just replace the board and not have to buy the whole motor.
fairbank56
#4 Posted : Saturday, August 22, 2015 5:59:13 AM(UTC)
fairbank56
Groups: Expert
No, not available separately.
Eric
