My Roper heavy duty dryer cuts off after running for 2-3 minutes. The heat seems OK. The vent/exhaust line is clear. What could the problem be? Thanks for any advice
Need model #. However, after it cuts off, when you restart it does it start or does it buzz/Hum? If it does, more than likely it is a worn out motor.
Originally Posted by: gmbdinc  Need model #. However, after it cuts off, when you restart it does it start or does it buzz/Hum? If it does, more than likely it is a worn out motor. I think the model # is RES 7646KQ2 and the serial # is MP 4495172. There is no buzz on a restart.
