jstaples
#1 Posted : Saturday, March 20, 2010 11:08:13 AM(UTC)
jstaples
I just had to replace a top burner plug in block and now, no matter where I set the temp., the burner is either all the way hot or off. Help!
gmbdinc
#2 Posted : Saturday, March 20, 2010 11:25:23 AM(UTC)
gmbdinc
Sounds like the burner control is shorted. Make sure you unplug it then take off the back control panel. Your part should be located in this link Control panel replacement parts for WHIRLPOOL RS675PXV0 | AppliancePartsPros.com
Burner Problems for Kenmore 790.99123404 Range (Oven Repair (including Ranges and Cooktops))
by whitedavidp1 1/17/2020 12:51:57 PM(UTC)
Whirlpool stove burner problem (Oven Repair (including Ranges and Cooktops))
by Cardiaccat 2/24/2019 5:22:18 PM(UTC)
Viking Gas Range Burner Problem (Oven Repair (including Ranges and Cooktops))
by pd78 1/23/2019 4:12:13 AM(UTC)
Wolf SB486 Burner Problem/Adjustment (Oven Repair (including Ranges and Cooktops))
by HRMCHAN 9/6/2016 6:51:06 AM(UTC)
Burner problem (Oven Repair (including Ranges and Cooktops))
by donnahi5 9/27/2015 6:13:22 AM(UTC)
One burner problem: on-off-or full heat; nothing else (Oven Repair (including Ranges and Cooktops))
by efahrens 7/20/2015 7:29:12 AM(UTC)
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 1/20/2015 8:35:01 AM(UTC)
GE Burner Problem (Oven Repair (including Ranges and Cooktops))
by HkyFrk 4/3/2012 6:56:33 AM(UTC)
Americana Burner Problem (Oven Repair (including Ranges and Cooktops))
by Ken King 2/9/2012 9:21:08 AM(UTC)
Off & on Burner Problem (Dryer Repair)
by Nancy McMullen 12/27/2011 9:03:37 PM(UTC)
by rnhamski 10/7/2011 5:01:44 AM(UTC)
oven burner problem (Oven Repair (including Ranges and Cooktops))
by richtfan 4/26/2011 2:00:03 PM(UTC)
by twarshavsky 10/4/2010 7:48:14 AM(UTC)
kitchen aid cooktop dual burner problem (Oven Repair (including Ranges and Cooktops))
by danjoc 4/12/2010 5:53:13 PM(UTC)
kitchenaid kgrt500bal2 front burner problem (Oven Repair (including Ranges and Cooktops))
by hgminnesota 10/2/2009 3:32:17 PM(UTC)
