smithscott
#1 Posted : Saturday, March 20, 2010 8:39:51 AM(UTC)
smithscott
My dryer quit heating but everything else still works fine. I replaced the heating element but that didn't fix the problem. So I checked the thermal fuse and it is good. the thermostat was also giving me a good reading. The thermal cut-off was not reading so I replaced it. I gave it a test run and everything was working great but the element seemed to almost get too hot and it set off the smoke alarm. then after a few minutes of running it quit heating again. I checked the new thermal cut-off I had installed and it is no longer showing me a good reading. what could be causing the thermal cut-off to keep tripping or blowing? is it the thermostat not working properly even though it shows a good reading? should I have replaced the thermostat at the same time I replaced the thermal cut-off? everything else that could be related such as proper exhaust seems to be okay. something just causes my thermal cut-off to blow. any advice is greatly appreciated. thanks in advance
#2 Posted : Saturday, March 20, 2010 11:20:54 AM(UTC)
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
smithscott
#3 Posted : Saturday, March 20, 2010 12:36:59 PM(UTC)
smithscott
thanks for the reply. when you say the heating coil are you talking about the heating element that the thermostat is attached to. just wanted to make sure I am thinking of the same thing. I just put a new heating element on the dryer but I re-used the thermostat. according to my meter the heating element and the thermostat are good. thanks
#4 Posted : Sunday, March 21, 2010 6:13:18 AM(UTC)
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406688.pdf
[COLOR="DarkGreen"]First Post[/COLOR]
[COLOR="DarkGreen"]So I checked the thermal fuse and it is good. the thermostat was also giving me a good reading. The thermal cut-off was not reading so I replaced it.[/COLOR]
I am assuming this is the thermal cut-off (fuse) near the heater.
Did you also replace the hi-limit thermostat?
They often come as a set, see item 6 in Section 3
[COLOR="DarkGreen"]
what could be causing the thermal cut-off to keep tripping or blowing?[/COLOR]
See below. It is not unheard of to get a heating element that is grounded right out of the box.
[COLOR="DarkGreen"]is it the thermostat not working properly even though it shows a good reading?[/COLOR]
It could be the thermostat is not opening.
[COLOR="DarkGreen"]should I have replaced the thermostat at the same time I replaced the thermal cut-off?[/COLOR]
See below
[COLOR="Blue"]Second Post
thanks for the reply. when you say the heating coil are you talking about the heating element that the thermostat is attached to.[/COLOR]
Yes
[COLOR="Blue"]I just put a new heating element on the dryer but I re-used the thermostat. according to my meter the heating element and the thermostat are good.[/COLOR]
Did you check it to ground/case/frame?
Here are things to look for with your type of problem.
When the thermal cut-off is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check it with a meter, should be around 10 ohms.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
smithscott
#5 Posted : Sunday, March 21, 2010 9:03:48 AM(UTC)
smithscott
hey denman, thanks for the reply. I'll try what you said. I appreciate the advice.
Samsung dv220agw - heating problem (Dryer Repair)
by jjandrews222 3/8/2021 6:18:21 PM(UTC)
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Dryer heating problem (Dryer Repair)
by Doehr 8/28/2016 10:41:56 AM(UTC)
Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by Jman1 1/20/2016 4:33:59 PM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Kenmore Elite HE3 gas heating problems (Dryer Repair)
by karl1970 12/24/2014 6:39:08 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
Diagnosing Heating Problem (Dishwasher Repair)
by glmoore0001 2/18/2014 10:16:59 AM(UTC)
oven heating problem (Oven Repair (including Ranges and Cooktops))
by 9point1 11/20/2013 9:30:19 AM(UTC)
LG LSE3092ST Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by parabola 10/8/2013 8:51:33 AM(UTC)
maytag stacked Dryer heating problem. (Dryer Repair)
by yudule 8/13/2013 10:30:40 AM(UTC)
by HOLLYTIM 6/11/2013 5:41:18 AM(UTC)
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 4/12/2013 4:53:45 AM(UTC)
Heating Problem Issues (Dryer Repair)
by dmikel12 10/8/2012 4:01:27 PM(UTC)
