dleejohnson
#1 Posted : Saturday, March 13, 2010 6:52:31 AM(UTC)
dleejohnson
I have checked for continuity on everything , even the timer, dryer still won't heat.
#2 Posted : Saturday, March 13, 2010 7:35:36 AM(UTC)
Please do not take offense but do you have have power.
Also when checking for continuity did you disconnect at least one side of any device you were checking. This ensures that you do not read an alternate/parallel circuit path.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
bowersj
#3 Posted : Saturday, March 13, 2010 10:14:41 AM(UTC)
bowersj
Our dryer still tumbles the clothes but will not produce any heat. The timer doesn't work on any selection except for timed drying. We have checked fuses/voltage/continuity. We have 240 V all the way to the heater coil. It stoped working after the unit was moved. Any help?? Please?:confused:
#4 Posted : Saturday, March 13, 2010 11:37:29 AM(UTC)
bowersj
Unless your unit is the same model number, please start a new thread/post using "POST NEW TOPIC" in this section.
Otherwise it will just get confusing.
It sounds like your heating coil is broken (open)
Many units get power directly from one side of the line when in timed dry but when in auto modes, they get power through the heating coil when it is turned off.
dleejohnson
#5 Posted : Tuesday, March 16, 2010 6:09:09 PM(UTC)
dleejohnson
thanks den man it was bad breaker
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
