ecarper
#1 Posted : Wednesday, March 10, 2010 7:48:25 AM(UTC)
ecarper
Freezer and refrigerator side are not cold enough. All the food in the freezer has defrosted and the temp in there is about 20 degrees and the temp on the fridge side is upper 40's to lower 50's. Compressor runs, condensor coil have been cleaned out, it runs a normal defrost cycle and when compressor is running, there is frost on evpaorator coils. Is it possible the thermostat on the evaporator is bad?
#2 Posted : Wednesday, March 10, 2010 3:56:05 PM(UTC)
Originally Posted by: ecarper Go to Quoted Post
...when compressor is running, there is frost on evpaorator coils...
How is the evaporator covered with snow? Are all coils covered?
Does the fan inside the freezer work?
#3 Posted : Thursday, March 11, 2010 1:35:29 AM(UTC)
If the evaporator coils are only partially frozen, you have refrigeration problems for a pro. to look at.
ecarper
#4 Posted : Thursday, March 11, 2010 5:13:48 AM(UTC)
ecarper
When I took the cover off of the back of the freezer only a quater of the evaporator had frost on it, it was all all the lower half. Thanks for your help.
ecarper
#5 Posted : Thursday, March 11, 2010 5:23:09 AM(UTC)
ecarper
What does that mean?
#6 Posted : Thursday, March 11, 2010 7:33:17 AM(UTC)
Ignore Wetop. you best get a pro. to look at it if it's worth it. You might have an evaporator leak or a bad compressor.
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Whirlpool Refrigerator WSF26C2EXY02 (Refrigerator & Freezer Repair)
by DLanier 12/4/2023 5:06:34 AM(UTC)
Whirlpool Refrigerator Issue (Refrigerator & Freezer Repair)
by jrbentley 11/5/2023 1:04:02 PM(UTC)
Whirlpool Refrigerator Model WSF26C2EXF01 not making ice. (Refrigerator & Freezer Repair)
by agarcia5 8/26/2023 4:53:02 PM(UTC)
Whirlpool Refrigerator Model ED25TEXHW01 (Refrigerator & Freezer Repair)
by jammer48 8/18/2023 1:05:09 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
Whirlpool Refrigerator making a rather odd noise (Refrigerator & Freezer Repair)
by dbdata 12/7/2022 9:55:57 AM(UTC)
Whirlpool refrigerator water dispensing issue (Refrigerator & Freezer Repair)
by andymayor 7/6/2022 2:22:17 PM(UTC)
Whirlpool refrigerator replacement ice maker (Refrigerator & Freezer Repair)
by MELLIOTT 6/9/2022 9:06:52 AM(UTC)
Whirlpool refrigerator Model Number et1mtkxkq07 (Refrigerator & Freezer Repair)
by Guest 5/13/2022 1:16:28 AM(UTC)
Whirlpool refrigerator won’t freeze (Refrigerator & Freezer Repair)
by Nick72 5/12/2022 7:37:51 AM(UTC)
Whirlpool Refrigerator GD5SHAXLQ02 - Door not dispensing ice (Refrigerator & Freezer Repair)
by z-vap 3/21/2022 5:33:58 AM(UTC)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
