labfreak
#1 Posted : Tuesday, April 8, 2008 12:11:48 PM(UTC)
labfreak
i have an old kenmore washer, model # 11082360810 serial # c32302409 just started not spinning, will fill, aggitate and drain but stops when it reaches the spin cycle, seems like lid switch possibly however when i tested it there is 0 resistance with switch acctuated and infinate with switch deaccuated. any ideas. thanks
#2 Posted : Wednesday, April 9, 2008 11:55:38 AM(UTC)
Pull the washer and remove the access panel on the back.
Check the wires to the magnet control (aka wig-wag) and the spin solenoid.
- The part number for the magnet control is AP3121800
The new magnet control comes with the complete installation instructions.
labfreak
#3 Posted : Thursday, April 10, 2008 5:51:14 AM(UTC)
labfreak
i have removed the access panel. it seem to me that the wig wag solenoids are both working properly. the spin solenoid activates while the other solenoid deactivates and vice verse. i dont know exactly what is supposed to happen when they switch, but the arm that the spin solenoid is on doesnt move while the other one pushes in. the motor stops and it is like the machine just shuts off. Possibly a timer? or maybe something else.
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
