strechrguy
#1 Posted : Monday, February 22, 2010 4:42:43 PM(UTC)
strechrguy
my washer will not spin or aggitate but will fill and drain and i just replaced the coupler a month ago i turned on the washer and watched under there and nothing was moving not the coupler and it makes a loud grinding type noise
sidfink43
#2 Posted : Tuesday, February 23, 2010 4:40:09 PM(UTC)
sidfink43
If your machine will drain then the motor is operating. Take it apart and inspect the coupling close up.
strechrguy
#3 Posted : Wednesday, February 24, 2010 3:12:22 PM(UTC)
strechrguy
you were right the coupler was cracked... why it did that being new i dont know but ill put another new one on thanks alot
sidfink43
#4 Posted : Wednesday, February 24, 2010 3:43:50 PM(UTC)
sidfink43
Well, it is unusual to have a second break, but the coupler is the weak spot, and it is designed to be that way so the motor or transmission is not damaged.
Glad you got it fixed, thanks for the update.
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
GE Washer Wont Spin or Agitate (Washer Repair)
by rangerjoey76 12/8/2013 11:55:34 AM(UTC)
Washer wont spin or agitate (Washer Repair)
by georgetherodean 7/18/2011 2:13:57 PM(UTC)
Whirlpool washer wont spin or agitate. (Washer Repair)
by sillyman 7/29/2010 10:09:30 AM(UTC)
ge profile washer wont spin or agitate (Washer Repair)
by mstrchief 10/16/2009 5:52:45 PM(UTC)
by referboss 10/3/2009 9:08:20 AM(UTC)
by referboss 10/2/2009 2:32:26 PM(UTC)
GE Profile washer wont spin or agitate (Washer Repair)
by volguy 6/10/2009 4:05:06 PM(UTC)
Maytag washer wont spin or agitate (Washer Repair)
by peiboy 5/16/2008 6:12:55 PM(UTC)
