My machine wont agitate or spin. It was making a loud nooise like a grinder . I opened the machine and found out that the sound was coming from motor and clutch .When i removed the belt the clutch dropped and i see lot worn out.
Is there a part that connects motor pump and the clutch.
Thanks in advance
You probably just need the clutch retainer clip AP2044903, possibly the clutch AP2045377.
Originally Posted by: richappy  You probably just need the clutch retainer clip AP2044903, possibly the clutch AP2045377. Hi rich thank you for your response. I have a new retainer clip , but my question is does the cluctch rotate freely or it has some locking to the motor. I see a hole in the motor pipe and there i am suspecting that something must be there which will be locked to the clutch . I saw some broken metal in that hole and small metal pieces when i opened the clutch . Regards
Just put the clutch back in and slip the retaining clip on, should work ok, clutch will engage when motor gets up to speed.
