3 Pages123>
Bob Reschke
#1 Posted : Monday, February 22, 2010 12:01:48 PM(UTC)
Bob Reschke
Bake and Broil units do not work and heat up.
Currently I know the following
1. AC power 120 volts on the DIC board is okay and other controls seem to be working.
2. Gas valve needs to be replaced; broil electrical pin outs show infinite on ohms meter instead of 216 ohms.. the bake side is okay.
3. The 8 - 18 VDC on the bake side is okay on the DIC board but the 8 - 18 VDC on the broil side reads 58 VDC.. that's not good!!
Based on this information I know the gas valve needs to be replaced but the question is whether the 58 VDC being read from the DIC board is from a defective DIC board or the power supply board. Which board is controlling the 8 to 18 VDC? The power supply or the DIC board?
Bob
#2 Posted : Monday, February 22, 2010 2:58:38 PM(UTC)
Hi Bob,
I'm afraid I did not get clear which part did you call "DIC board"?
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GS475LEMS1 30" Gas Freestanding Self Clean Range Sealed Burner Gold Line | AppliancePartsPros.com
Bob Reschke
#3 Posted : Monday, February 22, 2010 4:03:05 PM(UTC)
Bob Reschke
Hi Gene,
The board I am referring to is the Digital Spark Ignitor Control (DSI).. Is this board regulating the 8 to 18 VDC? If it is then I'm will need to replace DSI board along with the valve.
Bob
#4 Posted : Monday, February 22, 2010 4:58:28 PM(UTC)
Bob,
These DC voltage readings can be affected by the faulty solenoids on the gas valve. I would replace the gas valve/regulator first and I believe it will solve the problem.
- The gas valve/regulator Part number: AP3866825
File Attachment(s):
Theory of Direct Spark Ignition.pdf (95kb) downloaded 4 time(s).
angel fly
#5 Posted : Tuesday, February 23, 2010 5:53:58 PM(UTC)
angel fly
Bob
hey does it have an electric spark for bake and broil or an electric ignitor in the oven?
angel fly
#6 Posted : Tuesday, February 23, 2010 5:55:32 PM(UTC)
angel fly
i also have problem with a system silmilar to that have a question?
angel fly
#7 Posted : Tuesday, February 23, 2010 5:58:32 PM(UTC)
angel fly
getting f-2 on display whirlpool range sf1114pxb1sf11
#8 Posted : Tuesday, February 23, 2010 6:08:36 PM(UTC)
What exactly is wrong with your range?
The model number you posted is incorrect. Verify and repost it.
Bob Reschke
#9 Posted : Wednesday, February 24, 2010 3:36:26 AM(UTC)
Bob Reschke
Gene,
Thanks for the feedback. I did order the valve during this past weekend but was concerned that the increased voltage was being driven by the DSI board or maybe the power supply board.
Bob
#10 Posted : Wednesday, February 24, 2010 1:45:00 PM(UTC)
You are welcome Bob. Keep us posted.
Whirlpool gas stove bake not working (Oven Repair (including Ranges and Cooktops))
by Solomonsolomon 2/16/2021 7:46:53 PM(UTC)
Problem with my Whirlpool Gas Stove Model WFG525S0HT1 (Oven Repair (including Ranges and Cooktops))
by Airwolf1988 1/31/2021 3:54:22 PM(UTC)
whirlpool gas stove wrong error code (Oven Repair (including Ranges and Cooktops))
by colusapaul 12/6/2011 7:21:12 AM(UTC)
Whirlpool Gas Stove Acting weird (Oven Repair (including Ranges and Cooktops))
by colusapaul 12/3/2011 10:57:34 AM(UTC)
Whirlpool Gas Stove (Oven Repair (including Ranges and Cooktops))
by gdawgs 12/9/2010 10:23:05 AM(UTC)
Whirlpool Gas stove (Oven Repair (including Ranges and Cooktops))
by MissCindy 11/15/2010 6:11:51 AM(UTC)
Whirlpool Gas Stovetop (Oven Repair (including Ranges and Cooktops))
by VAS 8/9/2009 1:56:46 PM(UTC)
3 Pages123>
