Bake and Broil units do not work and heat up. Currently I know the following 1. AC power 120 volts on the DIC board is okay and other controls seem to be working. 2. Gas valve needs to be replaced; broil electrical pin outs show infinite on ohms meter instead of 216 ohms.. the bake side is okay. 3. The 8 - 18 VDC on the bake side is okay on the DIC board but the 8 - 18 VDC on the broil side reads 58 VDC.. that's not good!! Based on this information I know the gas valve needs to be replaced but the question is whether the 58 VDC being read from the DIC board is from a defective DIC board or the power supply board. Which board is controlling the 8 to 18 VDC? The power supply or the DIC board? Thanks
Bob
Hi Gene, The board I am referring to is the Digital Spark Ignitor Control (DSI).. Is this board regulating the 8 to 18 VDC? If it is then I'm will need to replace DSI board along with the valve.
Bob
Bob, These DC voltage readings can be affected by the faulty solenoids on the gas valve. I would replace the gas valve/regulator first and I believe it will solve the problem. - The gas valve/regulator Part number: AP3866825
Originally Posted by: Bob Reschke  Bake and Broil units do not work and heat up. Currently I know the following 1. AC power 120 volts on the DIC board is okay and other controls seem to be working. 2. Gas valve needs to be replaced; broil electrical pin outs show infinite on ohms meter instead of 216 ohms.. the bake side is okay. 3. The 8 - 18 VDC on the bake side is okay on the DIC board but the 8 - 18 VDC on the broil side reads 58 VDC.. that's not good!! Based on this information I know the gas valve needs to be replaced but the question is whether the 58 VDC being read from the DIC board is from a defective DIC board or the power supply board. Which board is controlling the 8 to 18 VDC? The power supply or the DIC board? Thanks
Bob hey does it have an electric spark for bake and broil or an electric ignitor in the oven?
i also have problem with a system silmilar to that have a question?
getting f-2 on display whirlpool range sf1114pxb1sf11
Originally Posted by: angel fly  i also have problem with a system silmilar to that have a question? What exactly is wrong with your range? The model number you posted is incorrect. Verify and repost it. Gene.
Gene, Thanks for the feedback. I did order the valve during this past weekend but was concerned that the increased voltage was being driven by the DSI board or maybe the power supply board.
Bob
You are welcome Bob. Keep us posted.
