MHOPPING
#1 Posted : Tuesday, February 23, 2010 12:31:00 PM(UTC)
MHOPPING
front of dryer drum sagging down about an inch, leaving a gap between the drum and the door where clothes get caught in
sidfink43
#2 Posted : Wednesday, February 24, 2010 9:02:45 AM(UTC)
sidfink43
Insert a wide, thin blade screw driver in the gap between the top and the front near the edges to release the clips that hold the top on.
Then pull the top forward. You should be able to see the problem. Also take off the back service panel and inspect the belt and pulley, as the problem may be there.
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Noise during rotation of dryer drum (Dryer Repair)
by Guest 1/5/2024 11:22:05 AM(UTC)
LG electric dryer drum cracking (Dryer Repair)
by Guest 1/22/2023 5:28:59 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Dryer drum not moving freely motor humming (Dryer Repair)
by bluefitness 1/18/2018 4:15:15 PM(UTC)
how to access dryer drum belt (Dryer Repair)
by Mikey3160 11/29/2017 9:47:44 AM(UTC)
Dryer drum won't turn (Dryer Repair)
by JudyStud 6/16/2017 11:18:11 AM(UTC)
MDE9700AYW dryer drum felt (Dryer Repair)
Belarus newhilldave 4/12/2016 5:58:05 AM(UTC)
Dryer drum spins too fast (Dryer Repair)
by meshow 12/7/2015 3:41:01 PM(UTC)
Low sitting dryer drum (Dryer Repair)
by blurintoone 11/25/2015 8:04:31 PM(UTC)
low sitting dryer drum (Dishwasher Repair)
by blurintoone 11/25/2015 7:16:49 PM(UTC)
May tag dryer drum thumps while running (Dryer Repair)
by Pajameson 7/30/2015 8:59:19 AM(UTC)
Maytag dryer drum removal (Dryer Repair)
by Tomjenks 11/14/2014 2:49:16 PM(UTC)
Whirlpool Duet electric dryer drum not turning (Washer Repair)
by drmjtn 11/2/2014 7:52:05 AM(UTC)
Dryer drum spins while not on (Dryer Repair)
by mr.danger 6/15/2014 5:59:49 AM(UTC)
