front of dryer drum sagging down about an inch, leaving a gap between the drum and the door where clothes get caught in
Insert a wide, thin blade screw driver in the gap between the top and the front near the edges to release the clips that hold the top on.
Then pull the top forward. You should be able to see the problem. Also take off the back service panel and inspect the belt and pulley, as the problem may be there.
