2 Pages<12
#11 Posted : Saturday, February 20, 2010 1:11:00 PM(UTC)
Have you checked the wires at the motor plug? A broken wire could cause it.
jroske
#12 Posted : Monday, February 22, 2010 2:43:07 AM(UTC)
jroske
Mine is a Kenmore/Whirlpool doing the same thing. I have replaced the capacitor and have had two motors sent from APP with no change. All the thing will do is sit and buzz.
#13 Posted : Monday, February 22, 2010 5:10:18 AM(UTC)
If the motor just sits there and will not shut down, you have a bad start circuit, probably a bad timer.
CCS FIXER
#14 Posted : Monday, February 22, 2010 11:43:19 AM(UTC)
CCS FIXER
Well I'll start from scratch
WP model LSR7233BQ1
Washer agitates great but when it comes to pumping out the water and spinning it stops and has a loud buzz sound. It doesn't matter what wash cycle it's the same thing. I checked the lid switch and it works fine, checked the pump for a clog and it was clear has a burn smell also.
Was suggested "Broken wire @ motor"---- Checked NO bad terminals, connections OR corrosion.... "Capacitor"---- Replaced with new, SAME results...... agitates in all cycles.. Stops when it gets to pump out water and spin all I get is a buzz in all cycles.
Suggested bad timer.
NEW QUESTION....... Can the timer be ohmed? IF so where can get the schematics showing what terminals to check & what the ohms should read.
OR do I have to buy a new timer??? 100 bucks +
Thank you ALL for your thoughts and suggestions
#15 Posted : Monday, February 22, 2010 2:28:46 PM(UTC)
Pull the timer cover and check for burnt contacts.
#16 Posted : Monday, February 22, 2010 3:48:53 PM(UTC)
Answered here: http://forum.appliancepartspros...t-spin-2.html#post192324
CCS FIXER
#17 Posted : Tuesday, March 2, 2010 12:56:47 PM(UTC)
CCS FIXER
I thank you guys for all of the information you have posted.
I pulled the timer out and removed the contact block so I could get to all of the contact surfaces. I saw where 3 of the contacts had welded together and others were just burned, Thanks richappy for that line of thought. I took a very small file and filed the contact surfaces off, re-installed the contact block back into the timer and plugged it in. Set it on spin and I could here the pump run and it started to spin turned everything off and installed a NEW timer today.
Anyway it's fixed and seems to be working fine
Thanks again
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
2 Pages<12
