Discuss
Washer will not Spin..
 in
Washer Repair
Sounds like the timer has gone bad. If you know how to read the timer chart in the Tech sheet
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not Spin..
  #11 (permalink)
Old 02-22-2010, 04:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the timer has gone bad. If you know how to read the timer chart in the Tech sheet, you probably can test it with an ohmmeter. Otherwise just replace it.
- The timer Part number: AP3965586
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 02-22-2010, 06:57 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Then the problem is probably in the timer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
whirlpool washer won't spin manually or spin boniam Washer Repair 15 06-29-2008 07:19 AM
