Sounds like the mold heater on the ice maker is stuck on. The ice maker has to be replaced.
The model number you posted does not come up and I'm not able to provide the right part number for the ice maker.
Verify and repost the model number of the fridge.
I thawed out the fill tube and it seems to be working fine now. Thanks
mapaburr,
If the feeding tube got frozen - the water valve is bad and has to be replaced. It's going to happen again pretty soon.
Thanks Glen: Problem was a simple freeze-back on the icemaker because of water being turned off. Defrosted tube from inside of ice-maker with hair dryer and blowed through it from the back--Works fine and normal. Thanks again.
