ron fleming
#1 Posted : Thursday, February 18, 2010 12:11:08 PM(UTC)
ron fleming
just opened top of dryer,seems like drum is loose.some of the felt packing on each end of drum seems displaced.whats out of whack here.can it be repaired easy enough.belt ,idler,spring seem fine.
thanks again ron:confused:
magician59
#2 Posted : Thursday, February 18, 2010 12:31:09 PM(UTC)
magician59
What is the original problem that caused you to open the dryer cabinet?
ron fleming
#3 Posted : Thursday, February 18, 2010 2:31:33 PM(UTC)
ron fleming
when starting dryer heard a humming noise and drum was struggling to start.the unit tripped out.emptied load and dryer would start although still struggling. slight smell of melting or burning while running.opened unit andbelt and idler look fine. opened top of unit,seems like drum might be out of sync .what holds the drum in balance.
thanks ron
magician59
#4 Posted : Friday, February 19, 2010 5:56:19 AM(UTC)
magician59
The tumbler sits inside the felt seals and is supported in the rear by the two rollers. the front of the cabinet supports the front of the tumbler. It sounds by your description that you have a weak motor.
Whirlpool Duet electric dryer drum not turning (Washer Repair)
by drmjtn 11/2/2014 7:52:05 AM(UTC)
Dryer elements are hot even when drum not turning (Dryer Repair)
by buddy1885 1/13/2014 5:31:59 AM(UTC)
GE Dryer drum not turning (Dryer Repair)
by mombert510 9/18/2013 4:02:32 AM(UTC)
Kenmore dryer drum not turning--belt is fine (Dryer Repair)
by Chrsitina White 7/23/2012 3:55:45 PM(UTC)
by blues_fan06 6/7/2012 11:48:10 AM(UTC)
Drum not turning (Dryer Repair)
by jdpen2 4/5/2012 2:46:20 PM(UTC)
by jlrhodes13 3/11/2012 9:34:23 AM(UTC)
Drum not turning belt off but in tact (Dryer Repair)
by Imflyn 2/14/2012 2:12:14 PM(UTC)
Maytag dryer drum not turning (Dryer Repair)
by cflick 5/12/2011 7:47:48 AM(UTC)
Dryer element on-drum not turning (Dryer Repair)
by golfindaddy 10/9/2010 3:14:28 AM(UTC)
Drier drum not turning (Dryer Repair)
by wittied 1/17/2010 9:54:42 PM(UTC)
by wajeemom 8/16/2009 11:08:38 AM(UTC)
by sharon warfel 5/27/2009 8:49:34 AM(UTC)
Gas Dryer still blowing heat - drum not turning (Dryer Repair)
by cathylyons 9/29/2008 6:23:07 AM(UTC)
Maytag Dryer: Drum Not Turning (Dryer Repair)
by miatahowie 7/23/2007 5:21:41 AM(UTC)
