jlrhodes13
#1 Posted : Sunday, March 11, 2012 9:34:23 AM(UTC)
jlrhodes13
The Model number is actually pye1000ayw. I have a Maytag Performa dryer, the drum does not turn but when I turn the dryer on you can hear the timer working. I took the dryer apart and all the connections are good the motor is not frozen or bound up. How do I test to see if it the motor or not.
JW Webster
#2 Posted : Monday, March 12, 2012 1:02:29 PM(UTC)
JW Webster
Thermal limit mounts on the side of the heating element. Pop the top to raise it so you can access the heater and thermal limit. Inspect the blower wheel for looseness and clean her up. A slipping blower wheel cause the fuse to blow. The dryer usually gets way too hot on top but takes fifty forevers to dry the clothes shortly before it goes out.
more here
Whirlpool Duet electric dryer drum not turning (Washer Repair)
by drmjtn 11/2/2014 7:52:05 AM(UTC)
Dryer elements are hot even when drum not turning (Dryer Repair)
by buddy1885 1/13/2014 5:31:59 AM(UTC)
GE Dryer drum not turning (Dryer Repair)
by mombert510 9/18/2013 4:02:32 AM(UTC)
Kenmore dryer drum not turning--belt is fine (Dryer Repair)
by Chrsitina White 7/23/2012 3:55:45 PM(UTC)
by blues_fan06 6/7/2012 11:48:10 AM(UTC)
Drum not turning (Dryer Repair)
by jdpen2 4/5/2012 2:46:20 PM(UTC)
Drum not turning belt off but in tact (Dryer Repair)
by Imflyn 2/14/2012 2:12:14 PM(UTC)
Maytag dryer drum not turning (Dryer Repair)
by cflick 5/12/2011 7:47:48 AM(UTC)
Dryer element on-drum not turning (Dryer Repair)
by golfindaddy 10/9/2010 3:14:28 AM(UTC)
by ron fleming 2/18/2010 12:11:08 PM(UTC)
Drier drum not turning (Dryer Repair)
by wittied 1/17/2010 9:54:42 PM(UTC)
by wajeemom 8/16/2009 11:08:38 AM(UTC)
by sharon warfel 5/27/2009 8:49:34 AM(UTC)
Gas Dryer still blowing heat - drum not turning (Dryer Repair)
by cathylyons 9/29/2008 6:23:07 AM(UTC)
Maytag Dryer: Drum Not Turning (Dryer Repair)
by miatahowie 7/23/2007 5:21:41 AM(UTC)
