all switches work but when you press the start button the buzzer sounds but the drum won't start turning. The full model number is 110-86873800 made by whirlpool
How do I trouble shoot this problem. The power is there just won't start
Cannot find info on this unit so following is just general info.
Is it the machine buzzer or the motor that is making the buzzing sound?
I am assuming that the blower des not work.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it. If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp. If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK. This may take 2 people Open the door Manually hold the door switch closed Push the start button and manually rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding connected. |
THIS FORUM IS DEAD!!!!!!! |
