kenneth L. Taylor
#1 Posted : Wednesday, February 17, 2010 12:31:45 PM(UTC)
kenneth L. Taylor
Installed replacement Ice Maker but it will not make ice unless I manually put water in tray. Tested water solenoid both externally and by pressing micro switch and tray filled made one cycle and stopped. Temperature around 8 degrees It appears it will not start cycle on its own starting or after it makes a manually fill batch. Everything in freezer is hard. Using well water system with water filter 20/40 setting on pump. Scratching my head.
Thanks Ken Taylor
#2 Posted : Wednesday, February 17, 2010 1:16:53 PM(UTC)
Hi Ken,
What was the original problem?
Quote:
...by pressing micro switch and tray filled made one cycle and stopped...
Which micro switch did you mean?
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FRT21IL5DWF Frigidaire/refrigerator | AppliancePartsPros.com
kenneth L. Taylor
#3 Posted : Wednesday, February 17, 2010 3:42:57 PM(UTC)
kenneth L. Taylor
Hi Gene
The micro switch is the one for the water solenoid. The old unit had the same problem. The ice maker will cycle threw one batch once water is added to the tray either manually or with the water feed micro switch. I originally thought it was the feeze thermostate then it made one cycle of ice and stopped. It appears that it will not restart the next fill cycle and it does not make small cubes it just stops running. I took the motor out of the circuit and rotated the cam manually and everything worked. I checked the motor and it runs when electric is Iapplied.
#4 Posted : Wednesday, February 17, 2010 4:47:53 PM(UTC)
Make sure the pressure in the water supply line at the water inlet valve is between 20 psig to 100 psig and the screen inside the water valve is not blocked. Otherwise I do not see what else can cause it.
kenneth L. Taylor
#5 Posted : Thursday, February 18, 2010 2:26:17 AM(UTC)
kenneth L. Taylor
Thanks for your help Gene. I took the water valve off to check the screen first thing. I checked the water pressure and the low is 20 psi. I plan on setting it to 30/50 but we have so much snow I can not get to the pump under the house to set it up. the house does not have a basement. Thanks again
Ken Taylor
#6 Posted : Thursday, February 18, 2010 12:36:01 PM(UTC)
You are welcome Ken. Keep us posted.
Owner's Manual (Oven Repair (including Ranges and Cooktops))
by johnwalchesky 11/16/2016 4:28:38 AM(UTC)
owner (Washer Repair)
by kennys handyman service 8/27/2015 6:38:36 PM(UTC)
Home Owner (Refrigerator & Freezer Repair)
by Dennis Steen 6/4/2015 8:29:00 AM(UTC)
Homeowner (Dishwasher Repair)
by Mark Hack 3/22/2015 7:58:01 AM(UTC)
owner (Oven Repair (including Ranges and Cooktops))
by tefley 6/20/2014 3:09:16 PM(UTC)
by wsdoc62@hotmail.com 5/2/2014 4:58:10 PM(UTC)
by Dwrcmc@aol.com 2/6/2014 9:49:15 AM(UTC)
dryer owner (Dryer Repair)
by ron myers 10/20/2013 5:17:17 PM(UTC)
Anyone have a owner's manual or know what each button does? (Dishwasher Repair)
by montanagrl 5/30/2013 12:11:10 PM(UTC)
owner (Refrigerator & Freezer Repair)
by skyguyd 1/21/2013 7:33:48 AM(UTC)
home owner (Refrigerator & Freezer Repair)
by wayfran67@q.com 1/8/2013 7:36:37 AM(UTC)
by wayfran67@q.com 1/7/2013 1:38:17 PM(UTC)
Homeowner (Oven Repair (including Ranges and Cooktops))
by jimbrie 11/21/2012 10:10:07 AM(UTC)
Owner (Dryer Repair)
by cupido18 7/24/2012 2:19:45 PM(UTC)
by mccabe 2/29/2012 9:44:50 AM(UTC)
