cupido18
#1 Posted : Tuesday, July 24, 2012 2:19:45 PM(UTC)
cupido18
My dryer run but not heat at all.
I did replace the heating element, Dryer thermal cut-off kit
I did check the fuse etc and is ok.
but I didn't check the timer control. I did clean the vent, still no heat.
Could you help me, please?
#2 Posted : Tuesday, July 24, 2012 4:07:00 PM(UTC)
Was thanked: 10 time(s) in 10 post(s)
Have you checked the power?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
cupido18
#3 Posted : Wednesday, July 25, 2012 1:59:52 PM(UTC)
cupido18
I want to say thanks. I did fix the dryer.
I checked the braker and it wasn't good. I replaced the braker and the dryer is working again.
Thank you very much for you help.
I told already to my friends about you.
You made me save to buy a new dryer.
Thanks again.
Owner's Manual (Oven Repair (including Ranges and Cooktops))
by johnwalchesky 11/16/2016 4:28:38 AM(UTC)
owner (Washer Repair)
by kennys handyman service 8/27/2015 6:38:36 PM(UTC)
Home Owner (Refrigerator & Freezer Repair)
by Dennis Steen 6/4/2015 8:29:00 AM(UTC)
Homeowner (Dishwasher Repair)
by Mark Hack 3/22/2015 7:58:01 AM(UTC)
owner (Oven Repair (including Ranges and Cooktops))
by tefley 6/20/2014 3:09:16 PM(UTC)
by wsdoc62@hotmail.com 5/2/2014 4:58:10 PM(UTC)
by Dwrcmc@aol.com 2/6/2014 9:49:15 AM(UTC)
dryer owner (Dryer Repair)
by ron myers 10/20/2013 5:17:17 PM(UTC)
Anyone have a owner's manual or know what each button does? (Dishwasher Repair)
by montanagrl 5/30/2013 12:11:10 PM(UTC)
owner (Refrigerator & Freezer Repair)
by skyguyd 1/21/2013 7:33:48 AM(UTC)
home owner (Refrigerator & Freezer Repair)
by wayfran67@q.com 1/8/2013 7:36:37 AM(UTC)
by wayfran67@q.com 1/7/2013 1:38:17 PM(UTC)
Homeowner (Oven Repair (including Ranges and Cooktops))
by jimbrie 11/21/2012 10:10:07 AM(UTC)
by mccabe 2/29/2012 9:44:50 AM(UTC)
by dbikerw 2/28/2012 8:32:33 AM(UTC)
