GeoTheMagicChef
#1 Posted : Tuesday, February 16, 2010 1:53:02 PM(UTC)
GeoTheMagicChef
I have a Maytag / Magic Chef OTR microwave (model CMV1000ADW). It was working fine until I had to take the door off to repair a crack in the frame. After replacing the door, the control panel will not respond. The display shows the time, but nothing happens when I press any key. I verified that all four door interlock switches are operational. Any ideas?
Jim7171
#2 Posted : Wednesday, July 6, 2011 8:56:59 AM(UTC)
Jim7171
I have the same Maytag microwave... the clock works but non of the control panel butons work so there's no starting the micro etc...
Please let me know what you think the problem is.
Thanks in advance, Jim
Jim7171
#3 Posted : Monday, July 11, 2011 5:52:40 AM(UTC)
Jim7171
The clock is the only thing that works when plugged in... the key pad is dead etc... when I open the micro door it blows the fuse and even trips the breaker. Can someone tell me if this sounds like a faulty door swith? If so, how do I test the to see which switch is faulty and is it necessary to unplug and bleed capacitor first? thanks for any help.
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 10/20/2016 5:40:57 PM(UTC)
GE Front Control Panel Not Working (Refrigerator & Freezer Repair)
by Wingernet 2/17/2016 5:41:43 PM(UTC)
oven control panel not working (Oven Repair (including Ranges and Cooktops))
by nocookintoday 1/26/2016 8:04:15 PM(UTC)
PLES389ECE Oven control panel not working (Oven Repair (including Ranges and Cooktops))
by tfmc369 10/26/2014 8:34:27 AM(UTC)
Control panel not working (Oven Repair (including Ranges and Cooktops))
by Dsteed1031 4/23/2013 6:53:31 PM(UTC)
New oven control panel not working (Oven Repair (including Ranges and Cooktops))
by MarshalW 2/13/2013 9:05:14 AM(UTC)
oven/clock control panel not working (Oven Repair (including Ranges and Cooktops))
by lasportsman 10/17/2012 3:43:15 AM(UTC)
Frigidaire Control Panel Not working; Range top works (Oven Repair (including Ranges and Cooktops))
by MThack 10/2/2012 11:21:36 AM(UTC)
Control Panel not Working (Dishwasher Repair)
by td1970 7/27/2012 10:42:06 AM(UTC)
Control Panel not working (Oven Repair (including Ranges and Cooktops))
by tmjenkins11 6/13/2012 7:46:08 AM(UTC)
by tinab 1/8/2012 3:56:39 AM(UTC)
Control Panel not working following self clean (Oven Repair (including Ranges and Cooktops))
by krozon 12/28/2011 4:36:35 PM(UTC)
Kenmore oven control panel not working -no "F" code (Oven Repair (including Ranges and Cooktops))
by DisneyMommy 10/19/2011 8:22:19 AM(UTC)
GE oven and control panel not working (Oven Repair (including Ranges and Cooktops))
by yardlet 2/15/2011 1:28:17 PM(UTC)
