Rick Riebesel
#1 Posted : Tuesday, February 16, 2010 7:37:41 AM(UTC)
Rick Riebesel
My dryer shuts off when using the timer but not when I use the more or less dry option.
#2 Posted : Tuesday, February 16, 2010 9:14:30 AM(UTC)
Replacement parts for WHIRLPOOL LE6090XTW0 | AppliancePartsPros.com
i cannot find a wiring diagram for this unit.
If you do not have it take a look in the control console, they like to store them in there.
It looks like your unit has a resistor going to the timer motor.
In timed dry the timer motor gets power directly from the line, L1 to Neutral 120 volts.
In Auto cycles the timer motor gets power through the heating coil when it shuts off and the resistor drops the 240 volts to 120 volts so that the timer motor does not burn up.
Unplug the machine
Check the resistor usually they are around 5,000 ohms.
If OK
Often the resistor attaches to OR on the timer and then trough a set of timer contacts to the timer motor (TM). Set the timer to the center of an Auto cycle, remove the resistor from OR and measure from OR to TM, should be 0 ohms.
IF OK
Check the heating coil
Unplug both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
GE gtd65ebsj3ws moisture sensor bar (Dryer Repair)
by Guest 11/1/2021 6:13:07 AM(UTC)
moisture sensors gone bad? (Dryer Repair)
by campbell42 4/7/2019 2:28:27 PM(UTC)
GE Adora Dryer Moisture Sensor Replacement (Dryer Repair)
by RedCoat999 12/14/2018 1:38:37 PM(UTC)
GE moisture sensor bars came loose (Dryer Repair)
by Dentbent 6/24/2015 8:52:37 PM(UTC)
DG 612 Moisture Sensor Location? And how to replace? (Dryer Repair)
by GregL564 2/22/2015 6:21:25 AM(UTC)
Whirlpool dryer - moisture sensor noise (Dryer Repair)
by JC_123 3/19/2014 4:21:14 PM(UTC)
Moisture Sensor Connect (Dryer Repair)
by DTdr2 5/29/2013 7:24:13 AM(UTC)
Moisture Sensor Test on Whirlpool Gas Dryer (Dryer Repair)
by skuddle 4/9/2013 10:42:48 AM(UTC)
Whirlpool Gas Dryer Moisture Sensor Access (Dryer Repair)
by skuddle 4/2/2013 11:28:42 AM(UTC)
Maytag Moisture Sensor Test (Dryer Repair)
by Jdfultonii 2/7/2012 3:32:27 PM(UTC)
Wires To Maytag Neptune Moisture Sensor (Dryer Repair)
by Rhythmking 11/30/2011 9:34:06 AM(UTC)
Whirlpol Moisture Sensor Dryer (Dryer Repair)
by Reid Carlson 5/23/2011 7:21:54 AM(UTC)
Moisture sensor burn-out! (Dryer Repair)
by ahjort 2/21/2011 3:39:26 PM(UTC)
Dryer doesn't heat up and moisture sensor not indicating wet clothes (Dryer Repair)
by Joan Cartier 10/3/2010 5:58:52 AM(UTC)
Dryer Moisture Sensor Out (Dryer Repair)
by usbradleys 9/16/2010 10:42:55 AM(UTC)
