Frigidaire Affinity Dryer AEQ7000ES1 I need some help connecting my Moisture Sensor on our dryer. The problem I'm running into is that I have 1 wire with 2 connects, but have 2 moisture bars with 4 connects. Which connectors do I use. I currently have my dryer hooked up using the top 2, however my dryer is still not drying like it should. DTdr2 attached the following image(s):
Yes it looks like it is connected incorrectly. You need one wire to each sensor bar. Click on the following to see a view how the back is connected. Part number: AP3790900
THIS FORUM IS DEAD!!!!!!! |
Hi there, guys, I'm not sure whether you solved your problen or not, but just in case...I want to share this link www.aquar-system.com/ They make all kinds of moisture sensors and meters, check it out.
