DTdr2
#1 Posted : Wednesday, May 29, 2013 7:24:13 AM(UTC)
DTdr2
Frigidaire Affinity Dryer AEQ7000ES1
I need some help connecting my Moisture Sensor on our dryer. The problem I'm running into is that I have 1 wire with 2 connects, but have 2 moisture bars with 4 connects. Which connectors do I use.
I currently have my dryer hooked up using the top 2, however my dryer is still not drying like it should.
DTdr2 attached the following image(s):
#2 Posted : Wednesday, May 29, 2013 9:12:09 AM(UTC)
Yes it looks like it is connected incorrectly. You need one wire to each sensor bar.
Click on the following to see a view how the back is connected.
Part number: AP3790900
DTdr2
#3 Posted : Thursday, May 30, 2013 5:20:10 AM(UTC)
DTdr2
Thanks denman.
hoidaBomhoimi
#4 Posted : Sunday, June 2, 2013 1:47:11 AM(UTC)
hoidaBomhoimi
Nataniel
#5 Posted : Tuesday, August 20, 2013 6:38:37 AM(UTC)
Nataniel
Hi there, guys, I'm not sure whether you solved your problen or not, but just in case...I want to share this link www.aquar-system.com/ They make all kinds of moisture sensors and meters, check it out.
