Originally Posted by: Gene  Sounds like the main control board is the culprit.
Gene. Thanks Gene. Now how do I remove control board?
You are welcome. The instructions are attached to the reply. Gene.
Hi Gene,
I was able to remove the control board with your instructions. One last question before I order the new part AP3995160 which is listed for Mode# WHDVH626F0WW. My model# says WHDVH626FFW which is almost, but not exactly the same. Do you know the difference between them in terms of the control board asm?
The model number you posted (WHDVH626FFW) does not come up. Verify and repost it.
Sorry, my mistake. The model number should be WHDVH626FWW. Can you check if the control board (AP3995160) is made for this model? Thanks.
Originally Posted by: yiming  Sorry, my mistake. The model number should be WHDVH626FWW. Can you check if the control board (AP3995160) is made for this model? Thanks. Are you sure there is no zero between "F" and "W" in the model number? Gene.
Yes, I am sure no zero there. I already ordered the part and will give it try after I receive it. Thanks.
Hi Gene,
The new control board didn't actually fix the problem. What should I do now? Please help.
Is the problem stays exactly the same or something changed?
Same problem as before. On startup, I set the model to 01 then tried "t10" and "t11". It doesn't spin at all. Also tried "rinse/spin" cycle with no spinning observed at the "spin" cycle, only a couple of slow back and forth spinning at the beginning.
One difference with the new control board is no "t14" available in the test mode. It goes up to "t13".
