I need a new motor, will the replacement motor accept the old motor switch hardware and mount the same. The old motor starts fine but the bearing next to the drum belt pully is bad. What parts do I need to replace this motor?Maytag LDE8626ACEThanks shortarib
THIS FORUM IS DEAD!!!!!!! |
