gwoakley
#1 Posted : Wednesday, March 26, 2008 10:30:43 AM(UTC)
gwoakley
When I override the door safety shutoff and watch the heat element it gets real hot for about a minute and shuts down. If I shut the dryer off and start right up again it does same thing. So it appears heating element is ok but something is shutting it down. Tried disconnecting some of the sensors, still acts the same.
Thanks for any info
Jerry
#2 Posted : Wednesday, March 26, 2008 6:39:18 PM(UTC)
Hi Jerry,
If you run the dryer with the door open, there is no proper air flow through the heating element which cause it to overheat and the high limit thermostat turns it "off".
What was the original problem?
gwoakley
#3 Posted : Thursday, March 27, 2008 4:30:43 AM(UTC)
gwoakley
The original problem is that the dryer gets warm but not hot enough to do a good job of drying clothes, it take forever to do a load, but it does get warm. It appears even with the door closed it does the same thing, heats up of a minute an shut off, thus leading to just a warm air flow??????
Thank you for your concern.
Jerry
#4 Posted : Thursday, March 27, 2008 8:55:55 AM(UTC)
Most likely cause of this problem is a clogged exhaust line and/or air ducts inside the dryer.
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
