jayb2274
#1 Posted : Thursday, January 28, 2010 10:29:24 AM(UTC)
jayb2274
my drier is not drying,, its warm inside not hot,, i have cleaned all the lint from the exhaust, it was packed and wet,,,,it vents very well to the outside now,,, i ran it with out the vent as well still not to hot inside.....i didnt measure the temp,,, in the drum or out of the exhaust,,,its only warm in the drum...
#2 Posted : Friday, January 29, 2010 1:01:07 AM(UTC)
Replacement parts for MAYTAG MDE9206AYW Dryer - Ele | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16023086.pdf
First I would check the voltage going into the unit to be sure it is a full 240 volts (L1 to L2)
Next I would check for a grounded element if grounded you would have no control over the heat temperature.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run and the thermostats cannot regulate it.
Next would be the Temperature Switch.
If all OK then it is probably one of the thermostats.
jayb2274
#3 Posted : Friday, January 29, 2010 6:12:13 AM(UTC)
jayb2274
Originally Posted by: denman Go to Quoted Post
Thanks for the info.. I do have 220v out of the wall, and into the unit,, are you referring to a grounded heating element...?
#4 Posted : Friday, January 29, 2010 6:17:25 AM(UTC)
[COLOR="Blue"]are you referring to a grounded heating element...?[/COLOR]
Not sure what the question is.
Hot water not hot enough (Washer Repair)
by jjuly 2/6/2024 7:46:17 AM(UTC)
my dryer is not hot enough (Dryer Repair)
by Guest 12/5/2021 11:38:26 AM(UTC)
Hot water fill not hot enough (Washer Repair)
by Slinger 2/11/2016 2:32:30 PM(UTC)
Kenmore gas dryer not hot enough (Dryer Repair)
by Brixey 1/22/2013 2:03:15 PM(UTC)
Not hot enough? (Microwave Repair)
by DonQuixote13 12/27/2012 2:11:51 PM(UTC)
GE oven-not hot enough (Oven Repair (including Ranges and Cooktops))
by paulbuscema 5/20/2012 7:21:33 PM(UTC)
Jenn-Air oven not hot enough (Oven Repair (including Ranges and Cooktops))
by craiglevitan 4/17/2012 6:45:10 AM(UTC)
Amana not hot enought (Dryer Repair)
by kevinburcham 1/16/2012 5:20:50 AM(UTC)
Whirlpool Not hot enough (Dryer Repair)
by jakemdr 3/9/2011 12:27:51 PM(UTC)
Estate Whirlpool gas dryer not hot enough (Dryer Repair)
by Remi32 1/10/2011 6:16:23 PM(UTC)
Dryer air not hot enough (Dryer Repair)
by digitalfreak 12/19/2010 10:51:43 AM(UTC)
Dryer gets warm, but apparently not hot enough. (Dryer Repair)
by Johnny54 11/21/2010 5:38:43 PM(UTC)
GE Dryer - Not hot enough (Dryer Repair)
by ryeg 6/3/2009 2:06:25 AM(UTC)
Gas dryer is not hot enough to dry clothes (Dryer Repair)
by Tryingtofix 3/8/2009 5:13:12 PM(UTC)
Dryer not hot enough (Dryer Repair)
by Captron66 2/23/2009 7:26:06 PM(UTC)
